メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Controllers for the Valve Index VR Headset released on June 28th 2019.
Thumbstick drifting in neutral position of it
Left hand thumbstick is in neutral position but game character moves on.
You have to push and pull the thumbstick in different directions to stop the drifting.
How to fix that?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 10
コメントを追加
3件の回答
最も参考になった回答
For those looking for a solution.
Look on reddit guide:
https://www.reddit.com/r/ValveIndex/comm...
This is the replacement part:
FJ06K-S Switch
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hello!
Sadly i don't know how is this controller really build, but i guess it's the same problem like in xbox controller. Analog inside just got broken. If you still have guarantee just send it back. If not, you need to replace it with new one. It's called 'FJ06K-S' probably. If you have soldering iron and some skills in soldering go ahead.
Good luck
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Ive dug around a lot in my index controllers because of drift and the capacitive sensor on top, as far as I can tell there aren't any official replacements online, but the joysticks just use 2 through hole potentiometers so for drift, contact cleaner might work. You can probably follow the instructions on replacing the strap to get the top open, but if you are under warranty, because of the limited part availability I would just get it replaced until they stop giving you replacements.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Tom Hans さん、ありがとうございました!
統計データ:
過去 24時間: 9
過去 7 日: 42
過去 30 日: 195
今までの合計 14,268
