メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
How do I troubleshoot Boot Loop even with front camera flex replaced?
I opened an iPhone 7 to check for water after getting it wet. No water. Phone accidentally turned on while opening it (no big deal). Turned it off, closed it up and then phone went into Boot Loop when I tried turning it back on. (Had no idea what that was so researched it). Found something on this site that said try disconnecting front camera flex cable. That worked. So I ordered a new flex cable. I was VERY gentle in replacing it with the new one. Problem is STILL there with new flex. How do I fix this thing? Someone mentioned the flex cable that runs between the screen pieces? How do I narrow down what the exact issue is? The Home button gets deactivated when the Front Camera flex is disconnected also. I want my front camera and Touch ID back!! I don't want to waste money fixing things that aren't broke. I am buying an iPhone parts phone later today. TIA !!
-caper
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
7 件のコメント
try replacing the screen
さんによる
@tech_ni thanks. But I’d really like to troubleshoot and know the exact issue instead of wasting money on more repairs willy nilly
さんによる
Unplugged Home button. Reattached front camera flex. Phone booted up. Would like to narrow down the exact issue.
さんによる
This is just weird, Kevin. My wife's 7 Plus had exactly the same problem and diagnosis, but in my case simply replacing the front camera / proximity sensor flex cable fixed it right up. Now that it's booting with the front camera still attached, can you reattach the home button and see if that does it? It seems like you're really close to a solution.
The only other thing I've heard is when I responded to another guy with the boot loop problem, another user chimed in and stated that in his experience a bad battery can also cause a boot loop. But the fact that it stopped rebooting when you unplugged the front camera should have eliminated the battery as a possibility.
Sorry, I know that's not much help, but it's all I got.
さんによる
@dadibrokeit thank you for your thoughts. I had a parts phone lined up and went to pick it up and the screen was smashed (which was failed to mention in the ad). $30 for a functioning phone (iCloud locked). 😔
さんによる
2件以上のコメントを表示
コメントを追加
2件の回答
ベストアンサー
Issue: boot loop
Troubleshooting done:
Disconnected front facing camera flex. Phone booted with no home button and TouchID disabled.
Reconnected front camera flex and disconnected home button. Phone booted without home button or TouchID.
Replaced front camera assembly. Same issue was present.
Replaced screen and swapped old home button and front camera. ISSUE RESOLVED
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
@rattice reattach the home button to see if it bootloops again if it does then you need a new screen
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
How do I know it’s not the home button or home flex? Hate to replace a screen only to have the same issue because it was the home button/flex the whole time … 🤷‍♂️
さんによる
コメントを追加
回答を追加する
Kevin さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 101
