メインコンテンツにスキップ
Guides and repair information for coffee and espresso makers from Jura Elektroapparate AG, a Swiss developer and distributor of home appliances.
102回答 すべてを表示
Impressa s9 empty grounds takes a full 10 min before it clears
Jura impressa S9 empty grounds won’t clear until you wait 10 minutes before re inserting the drip tray. I’ve tried every fix possible having to do with cleaning in the back of the tray and grounds in chamber. It is weird because if I’m descaling and it tells me to empty tray, it lets me insert it immediately. When it tells me to empty grounds, it does it 100% of the time. Are there Micro switches on an Impreza S9? If so where are they?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
The responsible parts can be seen in page 8 of the pdf, #510. There are no microswitches, just three contact plates on the drawer and their interior counterparts. It is very important that all the gaps between them are clean and dry, otherwise the device "feels" moisture and "thinks" that the water level in the drawer ist too high . If you want to look for the interior contacts, use this guide: Jura Impressa S Modelle Pumpenträger ausbauen
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
This page has videos for disassembly and refurbishing your device and an exploded parts diagram for the Jura S9 is this pdf file. Hopefully this will enable you to identify and rectify any problem.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Madura is leaking under the back of the machine. Everything else works great. I have an Empressa S9 that was purchased new in O2. I realize it’s old but it has been taken care of but I’d like to see if I can get in the back and fix the leak, but I need the key to open it in the back Help help
さんによる
You need an "oval drive bit" e.g. from iFixit. Or make your own.
さんによる
コメントを追加
回答を追加する
lisa anderson さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 30
今までの合計 513
