Restarts every 3 minutes because of thermalmonitord
Iphone se 2
https://zhidao.baidu.com/question/336459...
Thanks to Chris Stables answer, successfully fixed
Repair process
この質問は役に立ちましたか?
Iphone se 2
Repair process
この質問は役に立ちましたか?
The thermalmonitord sensor your log is referring to is mic 1 which is located on the Lightning Connector Assembly and will restart every few minutes if the CPU cannot communicate with the sensor. . Make sure you purchase one from a reputable supplier and not somewhere like eBay. Here’s the repair guide.
このアンサーは役に立ちましたか?
Thanks for your answer, I try to fix.
I tried this solution using the replacement part sold by ifixit, and it was a lot of fun, but I still have the same issue. The panic logs show the same cause. Any advice on possible next steps? --Thank you @imicrosoldering
過去 24時間: 0
過去 7 日: 6
過去 30 日: 24
今までの合計 2,596
6 件のコメント
Hello. What this Chinese guy did in this video is real? he tested the flex cable without entirely removing and installing it first. How did he do that? I am an amateur. I bought a damaged iPhone SE to change the piece with an original one , but I noticed that if I had bought a new piece it would have a sticky tape to fix inside the vessel of the phone and if I do just removing from the other iPhone SE , I wouldn't have the tape , can I do it with another thing or without any tape at all? THXS
Jesse henrique さんによる
@imicrosoldering could answer for me please?
@jessehenrique You can use some double sided tape if the charging port assembly has none left after removal.
Chris Stables さんによる
Thank you! I am confused about the 71 part of the guide iPhone SE 2020 Lightning コネクタアセンブリの交換 I really didn't get what to do. It is confusing the converter antenna cable and the small adhesive patch. I would like to know if I can open my iPhone with the conventional way (a suction) and heat because three months before this problem , my iPhone had a battery replacement in a AASP and they do something to make it dust and waterproof again , what is that and how can I open it properly knowing this?
@imicrosoldering
1以上のコメントを表示
