Is this CPU compatible?
I know about delidding the CPUs for the 4,1 (which I have) but will the X5675 on this page work?
Here it says it will work,
But do I have to find a delidded version?
@oldturkey03
この質問は役に立ちましたか?
@oldturkey03
この質問は役に立ちましたか?
Hello @beanman56
Apologies in advance but I am not Oldturkey03
But I do know that the cpu will work in a Mac Pro 4,1 BUT ONLY IF YOU FLASH IT TO 5,1 I cannot stress this enough,in order for this to work you need to do it
As for de-liding people really like to charge a premium for delided cpus so I would order a deliding vise and to it manually
I have a 5,1 and it has the Intel Xeon X5675 so just a little more assurance for you :-)
Hopefully this answers your question
このアンサーは役に立ちましたか?
Uhh, I'm not that confident in being able to do it.
Thanks for trying.
No worries:-)
過去 24時間: 2
過去 7 日: 4
過去 30 日: 9
今までの合計 160
12 件のコメント
@beanman56 probably be easier that to match the heatsink like this http://forum.netkas.org/index.php/topic,... but will cost you way more
oldturkey03 さんによる
Ughh.. could I just get a heat sink from a 2012?
Ben Capehart さんによる
@beanman56 probably not. To easy :-) Just shim it. Couple of washers and you'll be set.
oldturkey03 さんによる
so put washers on the screws so it's not putting too much pressure on the CPU (because it's made for a delidded CPU)when tightening??
Ben Capehart さんによる
@oldturkey03 - so put washers on the screws so it's not putting too much pressure on the CPU (because it's made for a delidded CPU)when tightening??
Ben Capehart さんによる
7件以上のコメントを表示
