メインコンテンツにスキップ
9月20日に発売された、Appleのメインストリームとなる2019年iPhoneモデルには、6.1インチLCDタッチスクリーン、デュアルカメラが搭載されており、6色から選べるカラーセレクションです。iPhone XRの継続モデル。
20回答 すべてを表示
iPhone 11 boot looping on DC power
Hello, I have an iPhone 11 which does not turn on. On the DC power supply, when I press the power button it does a normal boot sequence until about 120 milliamps, before going to 0. The boot sequence only lasts about 3-5 seconds. It just loops infinitely like this, and does not stop. 120 milliamps is the most it has reached and I'm not sure exactly what might be shorting. Does anyone know which chip or line this may be related to? Thank you!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Have you ruled out parts and software?
さんによる
Yes, I have ruled out parts and software. It is certainly a motherboard issue, right when it reaches 100 milliamps it drops to 0. It doesn't hang on 100, just drops to 0 immediately.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
This problem shows after dropped/water damage you don't mention. Check the capacitors near Nand or audio ic most be shorted in that case. So, you have to separate the PCB first and check might be loose contact with the CPU to PCB also cause such issues.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Hello, this phone was not water damaged and there is no signs of drop damage. I have separated the PCB, and did a visual inspection around the motherboard. From what I could see, nothing looked burnt or out of place. The main NAND lines also tested alright. I'm thinking there is a chip on the boot circuit which is shorting out and causing the phone to not boot, but I am not 100% sure.
さんによる
Check light-related circuits. I also saw the most problems with light-related circuits.
さんによる
コメントを追加
回答を追加する
Colby Morris さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 153
