MY iMac startup BLACK & ALARMING?
PLEASE ,HAVE LOOK AND HEELP ME WHAT IS WRONG,
http://www.youtube.com/watch?v=OoeTMwnvk...
WHAT CAN I DO ?
この質問は役に立ちましたか?
WHAT CAN I DO ?
この質問は役に立ちましたか?
It would seem your computer does not see any ram. You should check and see if your ram is fully seated. Link provided to the Apple beep code. Good luck.
このアンサーは役に立ちましたか?
+ If reseating your RAM doesn't solve the problem. Try different RAM sticks that are specified for your machine.
(Sorry , my lateness because of the mony )thank you "rj713" for your helpping to me I solved my problem (exactliy I did what you 'd told me, I'v bought different RAM sticks that are specified for my machine)It's working know so I'm happy.
IF ITs NOT THE RAM READ THIS
I have 2 iMac G3s> one iMac indigo summer of 2000 and one iMac G3 tangerine 1998-1999.
My tangerine iMac has a bad flyback transformer it pops every 5-10 minutes. When it pops a black horizontal line appears on the screen. I have hears the sound is an arch between the contacts. I have no idea how much it costs to fix this.
My indigo iMac has a few bulging caps and when i push the power button the white light comes on then shuts off> it makes a high pitch noise. After pressing the power button it turn on successfully. If you unplug it then you will have to go through this process again.
LEAVE THE iMACS PLUGGED IN IF YOU CAN!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 16
今までの合計 3,161
