メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2266回答 すべてを表示
Can an iPhone 7 front camera display be put into a 7 Plus?
Hello,
In the process of trying to fix my 7+, i broke the ribbon cable for the front facing camera display. i believe it also has the microphone and speaker attached. can i put an iphone 7 front display into my 7+? are these parts interchangeable?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
Hi @simms2021,
On our listing for the iPhone 7 Screen, the 7 Plus is explicitly listed as not compatible.
We do carry replacement screens for the iPhone 7 Plus, though! (Don't forget to get the display adhesive if you chose to buy the part only, rather than the full kit.)
Hope this helps!
iPhone 7 Screenの画像
製品
iPhone 7 Screen
$69.99
iPhone 7 Plus Display Assembly Adhesiveの画像
製品
iPhone 7 Plus Screenの画像
製品
$74.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Yeah, iphone parts are very rarely interchangable, even with other iphones! There will always be either a piece that wont physically fit (like a connector) or even if it LOOK S like it fits, if the resolution of both cameras isnt exactly the same it wont work. The hardware still needs software to work, and the software is designed to work only with the hardware it came with.
you used to be able to 'Frankenstein ' some older phones but they were not too reliable and it almost never worked with anything made by Apple, they want you to send your device in so they can fix it & charge a bundle. Replacing camera is easy, but make sure you get one for the EXACT model of iphone you have.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
No the cables are different sizes it wont sit correctly on the screen. The gold connectors where the speaker sits on wont sit correctly on the screen. Could it work possibly will it sit flush like it should no it wont.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
adelyn さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 21
今までの合計 356
