メインコンテンツにスキップ
How to grease fans bearing?
Hi,
I would clean my PowerBook G4 Aluminium 17'' fans cause those are really loudy, the noise sounds like something vibrating, rumbling.
So I've follow iFixit tutorial to access the fans but the top of the fan is covered by a little metal plug that avoid me to grease the axe of the fan, I don't know how to remove or open it.
Does someone have a solution to clean and grease those PowerBook fans?
Thx by advance
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
5件の回答
ベストアンサー
Hi, The noises you describe sound like the fan bearings are going bad and I suspect you probably need to replace the fans. By all means try cleaning the fans first--you may get lucky.
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Heat Sink & Fan Assembly Replacement
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
@ Jonathon: don't use WD40 to lubricate your fan instead use sewing machine oil. Check this link and you'll know why:
http://www.techrepublic.com/article/quie...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
You could blow the dust off, but it's really hard to actually disassemble and grease them. Try dusting it first (it's free?) and try that...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I have tried to clean fans with comprimed air but when i had turn on the computer nothing has change... same noise...
I have seen that: http://www.dansdata.com/fanmaint.htm
but on the Powerbook the little plastic plug seems to be a little metal plug and no solution to access the bearing...
Anyone have an idea a to remove this plug on metal boxed fan?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
im trying to fix a regular Massey fan (not computer fan) and its starting to squeak but WD40 doesn't seem to help it just shuts the motor down any tips? other then kitchen oil im looking for the grease that you would put on cars would you happen to know what its called?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
WNK さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 10
今までの合計 3,819
