メインコンテンツにスキップ
MacBook Pro 16インチの解体情報と修理ガイドです。2019年11月に発売されました。モデル番号はA2141とEMC3347です。
211回答 すべてを表示
The MBP is dead after battery drain
Hello!
Was an extremely happy owner of MBP 16" A2141.
2 Months ago became an owner of A2485.
I do have the bad habit of not Shutting down the computers I just closed the old one and put it under my bed.
As it's a great dust collector I decided to give it to my parents however for my big surprise it's not turning on.
Initially I thought that the battery is drained so I left it connected to the genuine 96W charger overnight.
On the morning I didn't have much luck as the A2141 still doesn't have any signs of life.
I tried different cables and made sure that the charger is working (by connecting the new MBP) and different USB ports.
So I started my investigation:
  1. Reset the SMC
  2. Reset the NVRAM
  3. Open the bottom of the MBP
    - clean the dust
    - check the batteries (look fine)
    - disconnect the battery
    - press and hold the power button for 10sec
    - connect the charger and press the power button
Unfortunately no luck. There wasn't a single movement of the fans, noice from the speakers or light from screen :-(
From what I understand there should be a faulty Logic Board.
The machine is out of warranty (that's why I did step #3 of the investigation).
1.5years ago I spilled a bit of water on the MBP. Turned it off immediately and wasn't using it for 3 days. On day 4 it was working except the screen, however it wasn't an issue for me as I'm using external screen. For my biggest surprise the screen turned on 2 days later.
Since then I never had any issues with the machine.
After opening it I noticed a tiny erosion (marked on the image) which I cleaned with alcohol
Ordered an USB C Power Meter Tester to check the power.
Wanted to ask for some advice what I should look for as a possible reason for this faulty machine?
I'm pretty handy guy and finished an electronics schools (15 years ago and haven't practices much since then as I focused on Software) so more than happy to dig and try to fix it myself (happy owner of the ifixit pro tech toolkit).
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 6
1件のコメント
Hey Handy Pol!
I'm having the SAME issue as you now! I have the A2141 and I put that in sleep mode and went on vacation for a month... Came back and I pressed the power button and I was in MacOS... But then I noticed I had 2% battery life so I quickly grabbed the USB-C cable and charged it... The battery icon didn't have a charger so it wasn't charging at all.. I figured, maybe a reboot might help.. So I rebooted.. At this time, the battery had depleted and it showed the 'low battery' icon with the lightning bolt... After that, I was never able to turn it on again...
I brought it out to the Apple store and they plugged it into configurator... It detected the computer but eventually timed out... The reason I got from them is a 'faulty' logic board... Somehow I'm not convinced...
I have tried all your troubleshoot steps except for number 3... I've changed new charger and USB-C cables... Tried another wall outlet... No luck...
Have you discovered or fixed the issue yet? I just ordered a new battery replacement but I haven't opened up the computer yet...
さんによる
コメントを追加
4件の回答
最も参考になった回答
Hi, I faced this issue last year for quite a few times!! My MacBook battery was drained by an external usb device (sound card) so my computer died and it dint charge with the regular charger and I was worried and took it to service center and they told I had to change my logic board! But I asked them to disconnect the battery and connect it again and after that I charged and laptop revived. After few weeks again battery drained by the same usb device and this time the same solution dint work. I kept the computer aside for few days and then charged it again and it worked. My laptop is still up and running
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
I unhooked my battery from the mother board and hooked it up to a power supply set just a couple volts above what it was reading and slowly nursed it up to about a 60% charge. Hooked everything back up, it booted and charged. It has never acted up again and I'm using it still now.
さんによる
I hooked up voltage direct to the battery once and brought it back to full charge but it was stuck in "service battery" mode and wouldn't accept a charge in the normal manner after that.
さんによる
Thank you guys so much for the response. I am glad to see how active this platform is. The Apple service centre did disconnect and reconnect the battery yesterday. I will keep it charging for sometime and hope it revives. Fingers crossed.
さんによる
Hi Josh Campbell, I have the same issue, I disconnected the battery from the motherboard and I tried to charge the battery with a power supply set at 12V but the battery didn't have any consumption, can you tell me how had you charged the battery?
さんによる
I've had the exact same issue with a 2019 MacBook Pro, which is only 4 months out of the 2 year John Lewis warranty. Was quoted £700 to fix this in the Apple store with no effort made on data recovery. Foolishly I still have a bunch of photography work on there that was not backed up, and an all important Football Manager save. It seems like there is no solution to the power issue on this thread, but I am adding my experience in a hope that somebody finds one and I can pick it up.
さんによる
コメントを追加
At this point I'm suspecting you have a dead battery either because of the corrosion damage and/or being left for so long in sleep mode.
While the USB-C power checker will help in seeing if the charging logic is even working it won't fix the dead battery. I would just bit the bullet here getting a replacement battery MacBook Pro 16" (2019) Battery, then carefully plug it in (leaving the original one in place) so you can check the charging logic using this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see iFixitでの質問に画像を追加する方法 it will show you what your USB-C power adapter is doing. As the shipped battery will only be partially charged your system should be charging it. If not you've proved you have a logic board issue besides the battery.
MacBook Pro 16" (2019) Batteryの画像
製品
$129.99
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
Hey Dan! Thank you very much for you answer. As I disconnected the battery followed by connecting the charger and trying to run the MBP isn't eliminating a possible battery issue?
さんによる
@kosmonaft - Sadly no, The newer USB-C (TB3) systems won't work without a battery, just using the charger.
さんによる
%#*@ it :-( Is there any other way to check if the battery is faulty? Don't want to buy a new one and find out that this isn't the issue. Before the dead I never had issue with it and was easily working 3-4hours on battery.
さんによる
@kosmonaft - Depending on where you buy it they may offer a return policy (restocking fee).
You still need to clean the logic board of the corrosion and it will likely need deeper repairs. So maybe it would be best to just find someone with the deeper skills to fix your system locally. There are quite a few independent Mac repair shops.
さんによる
コメントを追加
You have to use Apple Configurator from another mac computer while connected to the forward usb-c port on the left side of the offending macbook. Put it in DFU mode and "revive" from Configurator on the working macbook.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Sadly this won't here in this case.
さんによる
This solution only works if the computer is stuck at the low battery icon and won't boot even with the charger plugged in.
さんによる
コメントを追加
Unfortunately, I am facing the exact same situation. Let me know if anything resolved this issue. Apple is quoting an entire logic board repair which I cannot afford.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Same thing on my Macbook pro 2019 16inch, I knew this is a problem with the bios configuration the system, hence I believe after the battery is below 90% this problem can happen after you totally drain juice out of it.
Anyways, Apple Malaysia QDC at Sunway suggested I change the logic board which I am very aware they only want to make some bucks from us.
I even requested to purchase a new battery but they said the battery comes with the whole top case which is ridiculous, costing up to €500.
Anyways, this is my last year supporting Apple products anyways, it's been troublesome for the past 15 years. Horrible customer care service. Bullshit
さんによる
コメントを追加
回答を追加する
Handy Pol さん、ありがとうございました!
統計データ:
過去 24時間: 12
過去 7 日: 60
過去 30 日: 251
今までの合計 7,975
