メインコンテンツにスキップ
Repair guides and support for your Sanyo TV.
360回答 すべてを表示
TV won't register any ports at all. Channel 3 just Fuzz
I have a Sanyo DP26640. When I go to input all ports are checked but nothing I plug in to the TV will show on the screen except the old manual antenna. That picks up local stations just fine. I have a ROKU stick that was working plugged in to HDMI 1 but now I get nothing. Does the channel still have to be on 3? I tried a different ROKU that works elsewhere, I tried plugging in to different HDMI ports. Help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Ch 3 is only for things plugged into the ANT jack. Any port inputs like HDMI must be selected as an input. That is what the INPUT button on the remote does (sometimes labeled as something else). The fact that they are all checked on your setup only means that they are available as inputs, but you must select one. Hitting the channel button usually reverts the input to ANT. The Roku I have will cause the TV to change to the HDMI input if I hit any button on the Roku remote. Not all do that so you must change the input to the HDMI port the Roku is connected to.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Pamela Haymond さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 10
今までの合計 182
