メインコンテンツにスキップ
2020年4月に発表、発売された第二世代iPhone SEの修理と分解情報です。
20回答 すべてを表示
Battery Drain Overnight when airplane mode is off.
Hey,
A little while back I went through the process of restoring a 2020 iPhone SE, replacing its housing and replacing the screen. Although everything works well I have kept it in the closet and haven’t sold it due to a battery drain issue.
Regarding day to day use the battery life appears to be on par with most other 2020 SE’s, and has 89% Battery Health (genuine apple battery original to this iPhone). However, it continues to loose charge when the phone is off/‘stand-bye’. It is not irregular for it to loose 20ish percent from full, and even up to 30% overnight. Within three days even without use I wouldn’t the surprised if it has completely drained.
However, I tried turning Airplane mode on and the battery drain significantly reduced, to I think like within 10% (acceptable) in one night. Besides WiFi and my iCloud Account it is a running a clean version of iOS 14.4.2 and has no SIM Card or any apps/links running in the background. The screen itself was replaced, however it was with a genuine refurbished 8/SE Panel (so is an Apple LCD).
Just seeing if anyone has any ideas in what could be causing the issue before I sell it as is/consider opening it up again and investigating, just as I have sealed it down and don’t want to open it if it is an easy fix 🤪
Thanks (:
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Try backing up the phone and factory resetting it. Load the phone from the backup and see if anything changes. I hope this helps!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
TmG さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 536
