No Power ON, Battery is loading
Hello,
The MacBook ist loading the battery, but when I push the start button, I se no reaction, no sound, nothing.
Is there a option to bridge the power button on the logicboard?
Thanks!
この質問は役に立ちましたか?
Hello,
Thanks!
この質問は役に立ちましたか?
the power button is design together w/ the keyboard if you dismantle your MBP unibody carefully, you can check your power button
@Arthur Bagumyan
このアンサーは役に立ちましたか?
Assuming you have a 13" MBP Mid 2009, the pads are here:
The picture is only of a small segment of the board, but you can find this just above and to the left of the keyboard ribbon cable (the 3/4" wide cable that plugs in along the front edge of the machine).
If bridging the pads is unsuccessful, try disconnecting the keyboard cable and then doing it, because sometimes that helps, depending on the defect.
このアンサーは役に立ちましたか?
Thanks rdklinc, but it is nor working. Have you other ideas?
What is the history of the machine? Was it working? Has there been liquid damage, was it dropped, etc.? I would try bridging the pads with various tools, because some don't work. If you un-twist a paperclip, that should work. Beyond that, test the memory slots by leaving one empty, powering on, and then by leaving the other empty, and powering on.
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 1,252
1件のコメント
mfolta83 さんによる
