screen still dim after new inverter cable AND inverter board
Apple MacBook "Core 2 Duo" 2.1GHz 13" White A1181
A few weeks ago the screen went dim on my MacBook. Could see the desktop, and shining a bright light onto it makes it evident it's still fully functional other than the screen. The screen still lit itself up sometimes, usually just for a few seconds.
So I bought an inverter cable. Disassembled the macbook by the instructions here at iFixit (such a very useful resource!). But it was worse. I could still light up the screen by shining a bright light ONTO IT. But it didn't have those few moments now and again where it lit itself up, except when I lowered the brightness to 0 and then STARTED to raise it again, there'd be a brief flash of illumination.
So I bought an inverter board. This brought it back to the former state, where the screen is dim but lights up only sometimes.
I took it to Microcenter, bought a VGA adaptor cable and asked the repair person there if he wouldn't let me hook it up to a screen just momentarily so I could see if my motherboard was the problem.
We hooked it up, and the macbook plus his monitor made a 2-screen setup. I saw my Dock and some icons on his screen, and I saw a second desktop on my macbook's screen. No dimness at all! He said "I'm not seeing a problem here." I said "I know! How disappointing!" Heh. So we figured "Must be cured."
But it was just like when you go to a doctor for some chronic pain, and while you're there the pain's gone and he doesn't see what your complaint is.
As soon as I got the MacBook home, it was back to a dim screen. I can make it illuminate sometimes by just slamming the top shut and opening it. Or by dickering with the brightness control.
I don't know what else it is. Maybe the inverter board had the same problem as the old?
Why did it light up with no issues for several minutes while connected to an external monitor? Maybe because I'd been driving about in the cold and something that was loose "jiggled" for those few minutes into place, and then jiggled loose again when I drove the computer home?
I'm thinking of buying the whole top unit, LCD and frame and all, with the inverter board and inverter cables AND THE OTHER CABLES in it. I'm thinking there's still some cable issue.
Any and all advice is welcome! Thank you!
Chris
この質問は役に立ちましたか?
5 件のコメント
Thanks for the input.
I've reset the PRAM and SCU. (To reset the SCU is to remove the power cord and battery then hold the power button for five seconds, right?). No effect.
Is there a picture of what I'm trying to bridge to power the thing on while the topcase is off? I want to be very sure I'm touching the right parts together...
Microcenter had a refurbished white MacBook like mine for $500. I'm thinking if I'm looking at replacing one thing after another to get this machine working, I might save myself some grief just replacing it altogether... I've had this apart and back together 3 times already. Once for the inverter cable, once for the inverter board, then the night I saw it working well at Microcenter, I thought I'd tear it down again to make sure all the connections were secure.
Chris さんによる
I added a picture to my answer. Your board won't be red, but it will looks something like this between the optical connector and fan...you'll see a power symbol with two pads in the general area shown. Give it a few tries if necessary, because it can be tricky to successfully trigger the pads. $500 is a little high for an A1181...I'd pay a few hundred more and get a 13" MBP from the Apple refurb page.
rdklinc さんによる
Also, try booting into option mode (hold the option key down while powering on) and target mode (hold down "t" while powering on). If this screen does not light up when you go into these modes, then that rules out the operating system.
rdklinc さんによる
Jumpstarted it on the motherboard with no topcase attached -> no backlight.
Then also disconnected the battery connector/sleep sensor -> no backlight.
While it was still powered, I used the eraser of a pencil to drum about the relevant connections, and still no backlight.
So I don't know if I should be considering a new motherboard or a new screen unit (or a new computer ;-) ). It's still in pieces now, so if there are other connections I can test while it's open then now's the time.
Thanks again!
Chris さんによる
Chris, see my comment below. Thanks
rdklinc さんによる
