メインコンテンツにスキップ
モデル番号A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5もしくは2.8 GHz Core i7プロセッサ
432回答 すべてを表示
2.5 Crucial SSD SWAP wires
I followed all the install photos and directions. It’s just the connection forces the wires out instead of underneath with the new thermal sensor. Just want to make sure it’s okay before closing. Any suggestions, I’m open.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Are you replacing your HDD or adding it as a second drive?
Can you post a picture so we can see what you are encountering iFixitでの質問に画像を追加する方法
さんによる
@danj Hi, sorry I thought I had uploaded the picture. Here it is. Let me know if you need more. I replaced my HDD with the Crucial 1TB from iFixit. The only thing is the temperature wire harnesses makes the previous connection a little more cumbersome. I just want to make sure before I close that it’s acceptable.
さんによる
コメントを追加
1 件の回答
ベストアンサー
After comparing the photo you attached with photos from our teardown for this device, I don't think you'll have any issues with that. It looks to me like the issue is caused by a different shape in the fact that you have to use an adaptor to fit a standard-sized SSD where the old big-disc hard drive went. Worst-case, I would just use some basic electrical tape to secure the wires similarly to how they were before you replaced the drive.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
John Gliatis さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 5
今までの合計 31
