Is my gameboy advance is not chargeing but turn on
my gameboy sp is not chargeing it not saying it chargeing in any outlit it power and work but not charge is the charge port broken or the charger is
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Oscar Kniepkamp yes it could be your charger or it could be the charging port. Start off by replacing the battery. Your device is getting up there is age and the battery would be the first thing to replace. After that you can check the charger with a voltmeter. If that works out okay you know that your issue will be either the charging port, battery connector or the motherboard. Nintendo Game Boy Advance SPのバッテリー交換
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 14
今までの合計 75
