メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号:15-d017clのHP Pavilion修理マニュアルです。
Can replace this laptop's internal wireless card?
Having difficult time learning if the internal wireless card can be replaced or is it attached to the motherboard? I’ve tried 2 different USB wireless adapters but one they’re running, when I turn laptop off and back on—no Internet. Are ports too old to handle them? Thanks for any help you can offer.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
First of all have you checked to see if the wireless adapter is showing up in the Device Manager in Windows Control Panel. If it is there but has a yellow exclamation mark then it is possible the driver is corrupted. Uninstall it and let reboot and let Windows automatically reinstall the driver.
To answer your question:
Yes it can be replaced and is not soldered to the motherboard. Gently pry off the black antenna connecting wire, unscrew mounting screw and slide card out of socket.
Here are the disassemble instructions:
HP Pavilion 15-d017cl マザーボードの交換
The wireless card in circled in red in the first photo.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thank you! That’s a BIG help. Have a couple deadlines this week so may need to continue limping along til the weekend. But at least you’ve given me one more option to try! Your quick and knowledgeable response is much appreciated.
さんによる
Oh, and yes, I did go to Device Mgr and first tried uninstall/install ... no luck. Thanks!
さんによる
コメントを追加
回答を追加する
LinDee さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 19
今までの合計 608
