メインコンテンツにスキップ
2.2 GHz (Turbo Boost使用時最大3.4 GHz), 2.5 GHz (Turbo Boost使用時最大3.7 GHz)もしくは2.8 GHz (Turbo Boost使用時最大4.0 GHz) L3キャッシュで6 MBのクアッドコアIntel Core i7プロセッサ
774回答 すべてを表示
Touchpad not working after replacement
hey everybody!
I’d love to hear Your opinion on this.
My touchpad stopped working some time ago.
My computer is a Mid 2015 Macbook PRO 15”.
It started gradually, at the beginning it didin’t work once in a week, then more often etc etc. At the beginning, reseting the system did help. Then I have come to a moment when it totally stopped working.
So i went to a Mac repair shop and they diagnosed that the touchpad itself has to be replaced. Also they told me that my battery needed replacing. The price for repair was so big that i decided to do it myself as i have done repairs like this in the past.
So i bought a new touchpad and a new battery. Installed both, but my touchpad still does not work. Keyboard is working fine.
I double checked every connection etc, seems all good to me.
What can i do to move forward?
Thank You
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Without getting into board level troubleshooting, it sounds like it could be logic board issue. The deteriorating trackpad issue could have been a slowly dying component that was drawing too much current and overheating. Eventually this could damage whatever is driving that current from the logic board side. Replacing the trackpad with no effect is further possible evidence. Is the macbook working normally otherwise? One typical issue is it will go into "limp" mode - the trackpad has sensors on it that the SMC uses. If the trackpad sensors are not working the SMC will force the CPU into a mode where it runs at a flat 0.8GHz and the fans run full speed. The idea is that SMC can effectively manage the mac so it forces into a mode that is ultra safe. If the macbook is working fine otherwise (not in limp mode) then it may be that the section on the logic board that interfaces with the trackpad resposible for the pointer function is not working (and that sensor connection and function is intact). You could try another trackpad or try the trackpad you have on another machine - you want a verified working trackpad. then if it doesnt work, it means either connecor and/or cable and/or logic board issue. This is the "fun" of troubleshooting this stuff. good luck!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
John White さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 6
今までの合計 38
