メインコンテンツにスキップ
The Kenmore Elite HE3 is a washing machine by Kenmore.
669回答 すべてを表示
Kenmore Elite HE washing fails intermittently with an f20 error
During the rinse cycle my Kenmore Elite HE3 washing machine fails intermittently with an F20 error code. I can reset the washer to a different place in the wash cycle and it will continue . It doesn’t always do this but seems to happen more frequently when I put in a large load. I’ve tested the continuity on the inlet valves and they are ok. Does anyone have any suggestions.
Update (01/26/2022)
The model number of the washing machine is 110-47571602. There was a little bit of guck on the hot water inlet screen which I removed. It would have covered less than 10% of the screen at most likely closer to 5%. The water pressure is fine at least 60psi.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Hi @meconopsis,
What is the model number of the washer?
Have you checked that the water pressure at the output of the inlet hoses is OK and also made sure that the hose screen filters are clear?
さんによる
F20 appears to indicate insufficient water supply. Make sure hoses are not kinked.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi @meconopsis ,
Check that the water level pressure switch is OK and that the hose that it connected to it, is securely attached.
Here’s the service manual for the machine.
Go to p.4-6 to see the location and p.5-6 for how to test it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Rob Stuart さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 30
今までの合計 583
