How can I fix t612 loose 30 pin dock. Unit works thru aux port
Repair shops won’t do it claim micro soldering involved
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Micro soldering is required for most connector repair, there could be someone local to you that does this type of work
このアンサーは役に立ちましたか?
you COULD try hot gluing the connector - fix it in place with gaffer tape, and one dash of gun glue at a level plane with the bottom of the connector bowl.
If you are hearing crackling noises also, when connecting your 30 pin i-device, it could be the connector, but could also be interference. Google it, then.
このアンサーは役に立ちましたか?
Hot gluing wouldn’t repair the solder joints.
I was apparently asleep during reading. My apologies.
microsoldering of 30-pin
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 89
