メインコンテンツにスキップ
The Acer Aspire E5 series is a line of notebook laptops manufactured and sold by Acer, Inc., an electronics corporation based in New Taipei City, Taiwan. The Acer Aspire E5 series was introduced in 2015.
recovery disks, are they available somewhere?
My daughter acquired an Acer Aspire v5-122 P 0649. I would like to reset the laptop to factory and go from there. However, the problem is when I go into Disk Management, although all the partitions are there, ie, Recovery - 400MB, EFI - 300MB, Recovery - 350MB, New Volume (E:) Primary - 11.28GB, and lastly, Windows (C:) 226.04GB, with 79% Free Space.... The big problem is all the partitions except for Windows (C:) are 100% Free Space. Even Volume (E:) which lists 11.28GB says it is also 100% Free Space??? It all must be true because I have tried factory reset several times and absolutely nothing... I have searched a lot for someone who has just the factory recovery disks, and nothing... perhaps they don't even exist.. Suggestions?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I would do a clean reinstall Windows, not do a recovery. Recovery, if available, puts it back to the way it came from Acer with all the bloatware. You can download a copy of Windows from the MS site. Then lookup clean install of Windows.
B4 doing this, you must backup all your data files, documents, pictures, videos etc. Otherwise, they will be gone.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Ignore what Disk Manager says. That is not what you should be interested in.
You will need a USB flash drive or burnable DVD - USB flash drive is easiest and fastest.
Go to Microsoft:
https://support.microsoft.com/en-us/wind...
Select “ Windows 10 (Then select Download tool now.)” on the next screen select follow on screen instructions to make the Windows installations media.
You will want the 64 bit version and probably “Home” edition.
Let us know how it goes. just ask if you need any help.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Richard C さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 753
