メインコンテンツにスキップ
2020年10月13日に発表され、10月23日に発売されたAppleの2020年フラグシップスマートフォンです。6.1インチOLEDディスプレイ、トリプルレンズ、LiDARを搭載したリアカメラシステム、5G対応です。iPhone 11 Proの後継モデル。
91回答 すべてを表示
Face ID not working
My Screen was damaged and I’ve got a replacement but the ribbon cable off the original earpiece assembly was also damaged and I’ve had to also replace the assembly. As the sensors are paired with the phone once replaced the Face ID is not working. Can the new assembly sensors be programmed to work with the phone to re-enable the Face ID feature?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Unfortunately, the Face ID assembly cannot be repaired under any circumstances except by Apple or their authorized service providers. Face ID data is stored in something called the Secure Enclave in your iPhone. Any attempt to remove it to perform a repair or replacement will result in the secure enclave chip being destroyed or disabled without question, not to mention the data is secured digitally. This is impossible to reprogram yourself; I’m sorry for the disappointing response, but it is the truth. :(
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Hi Marcus, thanks for your response. Do you think it's possible to replace or repair the ribbon which connects to the front earpice assembly?
さんによる
Hey again, not a problem at all! While I can’t say for sure if this would be impossible, I do know that Apple employs tamper-resistant measures in this technology. If your device detects damage or any sort of tampering, there is a good chance Face ID will be disabled even if it is still functional. It may be worth a shot, but I would again advise that the chances are unlikely. I’m sorry for such disappointing answers :(
さんによる
コメントを追加
i have same problem on several phones, i believe that there are 2 components that you need to transfer to new flex and it will work, i will update when i receive new flex cables and do the swap - look on youtube - resq
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
shaun Henderson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 11
今までの合計 220
