メインコンテンツにスキップ
Samsung Galaxy Note 5は2015年8月に発売されたSamsung製のスタイラスペン付きファブレットスタイルのスマートフォンです。
272回答 すべてを表示
The Phone says "Temperature is too low" but its in a warm environment
How do I fix my Note 5 from saying this. Recently my Note 5 went in water and I dried it using rice, the phone wouldn’t turn on so I bought the Battery on iFixit here and I put the new battery in with no issues but then when I tried to charge the phone it said that the Battery Temp was too low. I went back in the phones and nothing was damaged so I’m confused now. Also does the Note 5 Battery on iFixit here have a temp sensor on/in the battery?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @effectiveark
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away.
Rice does not fix the problems caused by corrosion. Rice is for dinner, not repair
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is the ifixit Samsung Galaxy Note 5 guides that may help with the disassembly etc.for repairing your phone.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Effectiveark さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 17
今までの合計 100
