メインコンテンツにスキップ
2020年にAppleより発売されたトップラインのスマートフォンです。iPhone 12 Pro Maxは11月13日に発売されました。6.7インチ OLEDディスプレイとLiDARを搭載したトリプルリアカメラシステム、5Gネットワーク接続が可能です。iPhone 11 Pro Maxの継続モデルです。
found a broken iPhone 12 max
I'd like to fix this thing and either return it to it's original owner or sell it. The screen is shattered and it does not at all respond when plugged in…..but there seems to be no water damage and the frame appears perfect. i have a $200 quote for a new screen installed. what should I do?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
You could try to see if siri will work and ask her "who do you belong to" and she will tell you about who the iPhone belongs to. That's all she will tell you. You could also try to ask her to call "mom" or "dad", but I'm not sure if the phone will let you use siri after a restart. Now if you don't want to return this phone to the owner and you want to keep it, I recommend reading the answer by Chris Stables. Good Luck!!
さんによる
コメントを追加
1 件の回答
ベストアンサー
You will have to presume the phone will be iCloud locked. I would connect it to your pc or mac and see if it is recognised, you will probably need to put it into DFU or recovery mode if it has a passcode.
The only way to find the owner would be if it has not got a passcode and you can view there information but this will be highly unlikely.
 You really need to find the lock status before spending any money. You could try restoring it via 3uTools or iTunes and see if it will activate, you shouldn’t need a working screen for this. Or see if there is an IMEI number on the sim tray which you could check on a website.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Kurt Schasker さん、ありがとうございました!
統計データ:
過去 24時間: 9
過去 7 日: 10
過去 30 日: 15
今までの合計 500
