メインコンテンツにスキップ
The Asus X551CA is a 396.2 mm laptop computer with convenient features for everyday use.
29回答 すべてを表示
ASUS X551CA-SX030H memory RAM upgrade
Hello
Do you know if this particular model has slot to install additional memory?
In specification is information that is possible up to 12GB.
I found some motherboard from Aliexpress, and with the same processor has additional slot but not sure if original Asus was built in
https://it.aliexpress.com/item/328634703...
Thank you for info
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
I am not sure if your motherboard has a slot for you to install RAM. It seems to vary from computer to computer within this family and I cannot seem to get information on this specific computer. The only way we could find out if your computer has a RAM slot is for you to disassemble the computer, take out the motherboard, and take a picture of both sides.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
any chane to check out in some service manuals please? I have to buy memory and dont want return and open witbout reason. This is for mother in law so has to be done correct way :)
さんによる
@Piotr Krupicki See my updated answer.
さんによる
コメントを追加
回答を追加する
Piotr Krupicki さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 4
今までの合計 171
