airport/Blue tooth card replacement
The airport/Blue tooth card Im looking for is part number 661-4766. IFixit parts is suggesting a similar but different part for the 2011 MacBook. Will this replacement work?
The 2009 15” MacBook Pro AirPort board, Apple P/N 661-4766 sits within the Clutch cover with the antennas. It only offers WiFi as there is a second board for Bluetooth.
The 2011 15” MacBook Pro uses a combo board which is also larger AirPort, Apple P/N 661-5867 and sits within the main case
You need to use the correct part for your system.
製品
$79.99
製品
$42.99
このアンサーは役に立ちましたか?
Unfortunately then, the iFixit site search takes me to the wrong part. Where could I find the 661-4766?
@chjowh - The link works, iFixit is just out of stock. I posted both so you could see the images of the two parts.
Here's another source 2009 802.11n Wireless Card, Apple P/N 661-4766
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 75
