メインコンテンツにスキップ
The Panasonic Lumix DMC-FZ1000 is a digital single-lens camera with a rotating screen, released on July 27, 2014 by Panasonic.
31回答 すべてを表示
The micro HDMI port on my Lumix FZ1000 has stopped working.
I was using an adaptor to connect the micro HDMI port of my FZ1000 to a full size HDMI cable and all worked fine. The weight of the full size cable eventually bent the adaptor, it broke, and appears to have damaged the port on the camera as several other adaptors, specified as working with a FZ1000, will not work. I have reset the camera to factory defaults but there still is no video output on the micro HDMI port. Can the micro HDMI port be replaced?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Most cell phone repair business can probably replace the broken ports. It may take a bit for the parts to come in but unless you have done electric soldering in the past than for a camera being so compact I recommend a repair shop.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Brendan Mullan さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 9
今までの合計 172
