メインコンテンツにスキップ
The Olympus OM-D E M10 Mark II is a 16 megapixel mirrorless camera that was introduced in 2015. This camera can interchange lenses with its easy to use platform that is both user friendly and priced for amateur photographers without lacking professional capabilities.
5回答 すべてを表示
Camera not powering on
Display was not working fine so I have replaced flex cable. Right now the camera is not powering on but there is a light on front that is flashing. I have also measured voltage on mother board across flex cable from display and I am reading 2.9v max. Do I have to replace the entire motherboard?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
Why did you think the display needed replacing? Did you bang or get your camera wet?
さんによる
The display was flashing during tilting
さんによる
コメントを追加
1 件の回答
What happens if you disconnect the display cable from the logic board? Does the eyepiece display still work?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Vitt さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 17
今までの合計 285
