Error code -4SNS/1/40000000:TCOD Cooling Fan Issue?
After doing a hardware test (the quicker of the two), I came up with this error code.
4SNS/1/40000000:TCOD'''
I have Googled it and I keep coming across temperature sensor articles or people with kernel dump issues. The latter doesn't apply as there are no software or stability issues. So the temperature sensor(s) is either faulty or not connected. This would kind of make sense, as the fans do run heavy, even if the mac book isn't doing particularly much.
Is there a guide on how to replace/repair said temp sensors? Although I have installed ISTAT MENUS but all of the temperature readings do actually have readings. So they must all be connected, surely?
Any suggestions people?
Thanks in advance.
この質問は役に立ちましたか?
1件のコメント
From the last 3 characters of your serial #, your machine:
Core 2 Duo 2.2GHz Late 2007 - MB062LL/B - MacBook3,1 - A1181
ABCellars さんによる
