メインコンテンツにスキップ
対象のモデルはA1419 / EMC 2806 / Late 2014 または Mid 2015。 3.3 または 3.5GHz Core i5 または 4.0GHz Core i7 (機種ID iMac15,1)、EMC 2834 late 2015 / 3.3 または 3.5 GHz Core i5 または 4.0 GHz Core i7 (機種ID iMac17,1)のRetina 5Kディスプレイを搭載したすべて。
573回答 すべてを表示
What is the best mac format for new SSD and NVMe for photo/video edit?
Hello ,
I am going to install new Samsung SSD and NVMe into my late 2015 iMac. Would like to know what is the best type of formatting for these hard drives when I am going to install fresh Monterey OS for photo/video editing work?
Apple File System (APFS) or MacOS Extended (Journaled)?
By the way what about external ssd like Samsung T7? I read from few people that their external hard drive got problem after they used APFS!
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Using a M.2 SSD is risky! The signal lines for housecleaning and sleep are not present within the adapter or carried into the SSD so you run the risk of corruption! It makes no different which format the SSD has.
Monterey as well as the older macOS’s from Mojave onwards require APFS for the boot drive so if this drive will be the boot drive then you have no options APFS will be used.
So lets say you decide to use the SATA port drive as the boot drive it has its own issues when using APFS as APFS is a chatty protocol so the limited buffers within SATA can mess you up! Often people encounter hanged systems (frozen).
So using the PCIe/NVMe interfaced drive is the better from an APFS stand point. It also makes sense from a I/O perspective as it won’t be the bottleneck of the data flows, the I/O is still limited to the drives ability to read or write the data.
The video students and pro’s I deal with can’t have projects lost from drive failures and the performance of their system much be at its optimum. As such most students opt for a 512 GB blade drive and the pro’s go with a 1TB. I also deal with music artist and there we often go with a 2TB blade SSD as the nature of composing works better with the instrumental elements on the faster drive.
External drives are dependent on the interface they are using. a USB 3.1/2 drive via USB-A is best served using HFS+. A USB-C or Thunderbolt drive natively works better with APFS. But! RAID’ed drives work better with HFS+
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Studio Arash さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 1,158
