メインコンテンツにスキップ
15 inch "Desk Lamp" iMac G4 700MHz M6498 PowerMac 4,2
How to bypass putting in a password
I got one of these out of e waste, and decided to restore it. it works fully and the previous owner’s info is on there. I am wondering, is there is a way to bypass or reset the computer’s password so that i have full access to the computer?
also to mention i have a windows keyboard so what i can do on the mac may be limited by the keyboard.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
To get full access to the computer, you will need to reinstall MacOS. Do you want to install the MacOS that came on this computer or the latest MacOS compatible with this computer?
さんによる
When i got it it had 10.4.11, and i do want to keep some of the data on the drive. but i honestly want to be able to run mac os 9 and a version of os 10.
it currently runs os 10.4.11 and os 9.2, and it has apps like sherlock, ichat AV, acrobat reader 5.0, quicktime, itunes, quicken 2002,sonos desktop, appleworks 6, and many other apps i want to keep
さんによる
@andrewsawesome I got it with 10.4.11 and I want to run Mac OS 9.2 and macOS 10, although I cannot decide on a version and might just go with Mac OS 10.4.11 again
さんによる
コメントを追加
2件の回答
最も参考になった回答
You will need to reinstall MacOS. To reinstall MacOS on this computer you will need the (re) installation CD(s).
このアンサーは役に立ちましたか?
スコア 1
8 件のコメント:
@andrewsawesome No I don’t have any Mac OS install CDs
さんによる
@Roman See my revised answer.
さんによる
It just boots up normally for whatever reason
さんによる
@andrewsawesome it doesn’t go to it it just boots up normally when I hold down the buttons
さんによる
@Roman What happens if you:
1. Start holding Command+R
2. Press the power button.
3. Keep holding Command+R until the "MacOS Utilities" screen or the login screen shows.
さんによる
3件以上のコメントを表示
コメントを追加
@Roman - Sorry your system doesn’t offer recovery services (intel systems only)
The proper way is to use the grey bootable CD the system came with and using the menu option to reset your firmware password with it.
There is another way and thats removing one of the SO-DIMM’s and PRAM battery and then with no cord plugged in pressing and holding the power button for 15 secs to fully drain the logic board. Now you should be able to get to your drive.
You might encounter this error "To continue booting, type ‘mac-boot‘ and press return”
Follow this Apple TN: PowerPC: "To continue booting, type ‘mac-boot‘ and press return" Message
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Roman さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 33
今までの合計 432
