Why is no fuel getting in the cylinder an not starting
Is there any way any one has a manual for it
この質問は役に立ちましたか?
この質問は役に立ちましたか?
change the gas line and remove the carburetor. use carb cleaner and remove everything to pieces and blow the cleaner in every hole. the float bowl injector is the screw that holds the gas reservoir of the carb to the engine. this is usually the culprit and needs to be cleaned.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 742
3 件のコメント
Hello snsjss
Ethan さんによる
@walker34 your blower a Homelite backpack blower (bp250)? If not we need more info about what engine it has etc.
oldturkey03 さんによる
Plugged gas line, fuel filter, fuel valve or carburetor gummed up.
bill さんによる
