メインコンテンツにスキップ
2nd-generation magnetic AC power adapter for MacBook products, first released in 2012. Not compatible with previous generation systems. Available in 45W, 60W, and 85W versions.
26回答 すべてを表示
Is there a known Mag-Safe II to Mag-Safe III adapter available yet
I’m working on a new 14” M1 MacBook Pro and was so glad to see the return of the Mag-Safe adapter but it is an updated version of the Mag-Safe II only a little longer and slimmer. I am looking for an an adapter to use on the Mag-Safe II to convert it to a Mag-Safe III but have been unable to locate one yet. Are the any alternatives?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
Boy @mayer you couldn’t wait ;-}
I’m not sure if it would work either way.
Apples MagSafe & MagSafe-2 used a one wire dialog that was unique to them. While the MagSafe-3 is similar in that its five contacts I’m not sure what Apple has done here.
If you review the iFixit teardown 2021 MacBook Pro Teardown: A Glimpse at a Better Timeline The green three chips on the left are top to bottom MagSafe, USB-C port 1 & USB-C port 2 and all three are using the same Apple APL1098/343S00515 Power Management chip so I’m surmising the dialog is based on the USB-C power spec not Apples one wire comm connection.
Sorry Mayer ;-{ If someone is able to do it, its likely going to take a bit of time before they get released.
So how is it? And which one did you get?
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
@danj It's one day old, M1 Pro that I'm transferring user data over from her old Mac. Apple wants $49 just for a cable: https://www.apple.com/shop/product/MLYV3...
さんによる
@mayer - You mean its not even yours ;-{
I'm seriously thinking of going with the 16" M1 Max 32GB 1TB drive. The notch is the only thing holding me back.
The cable is the weak link in the older chargers at least Apple smarted up giving us the ability to replace it without the charger and yes, its to expensive!
さんによる
@danj The cable appears to be much better quality, made of woven material rather than the old plastic.
さんによる
@mayer - Yes! But will it last longer, I hope so for such an expensive cable.
さんによる
コメントを追加
最も参考になった回答
I guess it’s not going to be easy. Looking at the teardown of the MagSafe3 cable, it looks like a Type-C PD cable in disguise, so none of the old protocols work.
MagSafe to Magsafe2 adapter is basically just a passthrough, not possible with MagSafe2 to MagSafe3.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
im just wondering why those magsafe 2 to type c adaptor with like a sd card slot and what not have not just slapped a magsafe 3 adapter on the end i see female type c -> magsafe3 and type c male <- magsafe2 why not combine these?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
mayer さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 31
過去 30 日: 118
今までの合計 4,739
