TS0P sensor failure - fans stuck at max speed but trackpad works fine
Replaced the SSD in this system and been using it for a couple of weeks with no issue but now fans spin at full speed and laptop is very slow!
Running Apple Hardware test I get this error: 4SNS/C0000008:Ts0P--124
After a little investigation I found this is a sensor found in the trackpad so I replaced the trackpad and trackpad flex cable with a known working one, however the system still runs at max fan speed and displays this error.
Have also tried PRAM and SMC reset and nothing happens!
2 件のコメント
Did you install an OEM Apple SSD from that same model? Or a 3rd party model? I know the SSD has temperature sensor lines that talk to the SMC which may trigger issues like this in a non OEM SSD. But I would think that issue would have cropped up immediately and shouldn't be triggering that sensor in the trackpad....
Have you checked the trackpad connector on the board? I would pay particular attention to some of the pins towards the middle which are the lines that go to the SMC.
Alisha C さんによる
@flannelist Yes the SSD I installed was an OEM. I’ll have a look at the trackpad connector but I know the device hasn’t experienced any water damage.
Tom さんによる
