メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2020年4月に発表、発売された第二世代iPhone SEの修理と分解情報です。
Taptic Engine Motor weak vibration
Hi!
I have Changed Back Housing on an iPhone SE2020 which previously was bent. After that I have fitted back everything and I have tested vibrator motor but it is very weak. It makes very tiny sound or vibration but it is not normal.
I have tried an 2 good iPhone 8 Taptic Engine but it is the same problem.
Every other function of the phone works perfect except this.
The board has no damaged components on it.
Any suggestion how to diagnose or move forward? Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
I have never encountered this problem being a logic board issue. It will be a parts issue. Install the logic board into a known good housing and test.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
I've done it already.... Drives mad
さんによる
Problem still exist
さんによる
Strange to me, I did as well never encountered this problem before....
さんによる
コメントを追加
Do you have access to a microscope? It is possible that the board could have sustained damage that is not visible to the naked eye. I would also try cleaning any connections it uses.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
YES! I have checked under Microscope. Also checked the ARC IC chip and checked did readings no short found.
For now I have ordered another new Taptic Engine to check.
さんによる
Also checked with NEW dock flex which did not resolved the problem.
さんによる
コメントを追加
Hi, i have similar problem, but my Taptic Engine go laud non-standard, i even order new housing and the solution for me was changing the dock connector. If you have access to new one? You need to instal to the phone to proper test it.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have a spare dock flex. I have tested as well but problem still not resolved. today I have ordered a brand new dock flex I will check if that make any difference.
さんによる
コメントを追加
回答を追加する
Peter Hupuczi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 16
今までの合計 477
