メインコンテンツにスキップ
The Bose Wave Radio AWR1-1W, also known as the Bose Wave Radio I, was released in 1993. A countertop AM/FM radio system with a high performance stereo tuner and two independent alarms.
39回答 すべてを表示
My Bose Wave Radio makes distorted humming when plugged in
This question was asked already but maybe I have more luck than the previous person. When I plug in the Wave Radio it makes a distored noise. I assume there is a electrical issue. Is it possible to save it from the trash?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
@rahhh can you post an audio file so we can hear what it sounds like? You will most likely have to take it apart, so post some good pictures of your circuit boards etc. That way we can see what you see.
iFixitでの質問に画像を追加する方法
Failed electrolytic capacitors are a possibility but one cannot rule out bad audio IC's on the amplifier circuitry.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Can you open the radio and check for any leaky or bulged capacitors? I have attached a picture below for reference.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
r z さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 8
過去 30 日: 27
今までの合計 676
