メインコンテンツにスキップ
1.83、2.0、2.1、 2.16、2.2、または2.4 GHzのいずれかのCore 2 Duoプロセッサーを搭載したModel A1181
1206回答 すべてを表示
Help find J9001 LVDS connector from A1181
Please help identify (Brand, part no) LVDS connector marked J9001 on K36 MLB logic board of Macbook A1181
It has 22 visible pins, although on schematics there are 26 pins (4 are casing soldered to GND).
Thanks a lot!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
The part is only listed as S-050162B F-RT-SM on the schematic. I was unable to locate it via Google.
I doubt you’ll find the logic board connector as a spare on its own. The best I can suggest is locating a junker to acquire the part. That then gets into what you can find and the costs.
Depending on which model you have you might want to just swap out the logic board as this is not an easy connector to desolder.
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
Thanks, but i wanted to develop new device with this connector, so i need to get them fresh somewhere.
さんによる
@nielsbor - While I commend your efforts to re-use parts.
This series MacBook display uses CFL's for its backlight logic so it also has a power inverter which would also need power besides the LCD panels logic. I'm sure the CFL tubes and inverter have worn-out given the systems age (dim or discolored images).
Also keep in mind electronics has transitioned from LVDS signaling to eDP (iDP) signaling for displays as well.
さんによる
@danj This very macbook has pretty alive backlight. I connected backlight connector to the same adapter. It has +12, +5, GND, PWM. So it works
さんによる
さんによる
@danj ok but i dont need it at the moment
さんによる
コメントを追加
回答を追加する
Niels Bor さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 87
