メインコンテンツにスキップ
Manufactured from 2004 to 2009, the Vino 125 has a 125cc engine.
22回答 すべてを表示
Engine is making a bubbling gurgling sound like a percolator.
Bubbling gurgling sound in engine after it warms up. Drained and flushed radiator and oil. Both normal no discoloration. Engine also cracks back at full throttle. Any suggestions or thoughts?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Sounds like the radiator is not holding pressure. Try replacing the radiator cap first.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It's holding good and snug, never had any problems with it. Doesn't leak or anything like that.
さんによる
コメントを追加
Richard Mallette “Engine also cracks back” could be a timing issue as well as a fuel delivery issue. The “Bubbling gurgling sound “ could be caused by air in the coolant system. You did not tell us if this all just started or if this has been going on for a while.
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
Just started yesterday
さんによる
And is 49cc single cylinder
さんによる
The coolant was kind of low when I dumped it and replaced it, but how do I purge it if air did get into the system?
さんによる
Richard Mallette what is the exact model number for your scooter
さんによる
コメントを追加
回答を追加する
Richard Mallette さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 8
今までの合計 82
