メインコンテンツにスキップ
Released March 2019, identified by model number SM-A305FZRFINS
87回答 すべてを表示
My phone will randomly lock my screen and rapidly
For the last few days out of no where my phone ( Galaxy A30) will lock and unlock itself as if the power button has been pressed, and will act as if the button keeps getting clicked, the screen will start flashing rapidly when it does this, the power button doesn't feel stuck or anything, so my first thoughts is that the problem is a software issue, I've turned it on is safe mode, wiped cache partition, and finally I've done a factory reset, I can't find any other problems quite like this. I have tried keeping the device turned off for a while and fully charging the phone, but it keeps doing the same thing, if anyone has any ideas what could help me resolve this, I would appreciate this, So I can know what to get fixed. Please. Thank You.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
5 件のコメント
Does the phone ever randomly try and turn on? The power button might be broken, but it might be a software or processor issue
さんによる
Is your phone a Samsung Galaxy A50 or A30?
さんによる
@teardowns101 I'm really hoping it's a powerbutton issue, cus a processor issue means the phone's done for right?
さんによる
@Jerry Oti Yes, if the processor is having an issue it is almost certainly unfixable (unless you buy a used processor and board). However, it is much more likely that the power button was damaged and needs replacing
さんによる
コメントを追加
1 件の回答
ベストアンサー
I'm almost certain your issue is a shorting power button flex ribbon. You can get a new one here.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I'll second that
さんによる
Okay, I just ordered it, it's coming with the full Middle Frame/Bezzel. I hope it fixes it thanks @andrewawesome
さんによる
コメントを追加
回答を追加する
Jerry Oti さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 16
過去 30 日: 76
今までの合計 4,708
