Kobo - Replacement button
I’m trying to find a replacement button for my Kobo Ereader, the rubber went brittle and crumpled :(
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Most of them have very generic buttons found in many devices, but usually requires soldering to replace them. Heat station and an iron would be requite usually.
If it’s the type of button I’m thinking about you may find some on digikey or amazon sometimes.
Can you send a picture of the button?
I hope this helps
このアンサーは役に立ちましたか?
Did you find a solution? I have a white Kobo 2009 (no wifi). The rubberized square button on the front has deteriorated and crumpled too.
https://kolico.ca/tmp/kobo1-IMG_20210916...
A closer look:
https://kolico.ca/tmp/kobo2-IMG_20210916...
:( This is a sad time for me.
Can anyone think of a suitable hack?
このアンサーは役に立ちましたか?
I have the same problem, would love to hear a solution
過去 24時間: 4
過去 7 日: 31
過去 30 日: 110
今までの合計 2,178
2 件のコメント
What model is your Kobo e-reader?
Andrew S さんによる
It's a 2010 Kobo WiFi
Caitlyn Patterson さんによる
