メインコンテンツにスキップ
2020年3月に発売されたインテルプロセッサ搭載MacBook AirモデルA2179の2020年リフレッシュモデルの修理・分解情報です。
20回答 すべてを表示
Laptop Wont Turn On
Hi Community,
All of a sudden my laptop wont turn on, wont charger etc. just nothing. Is there any diagnostics that I can do myself without sending to apple store or local guy? It seems as though it's the battery, no keyboard lit up, nothing.
I have a multi-meter fyi and I have the fixit screwdriver kit. Can I test the battery taking off the back cover?
Thanks!
Al
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
7 件のコメント
Will the laptop turn on if you disconnect the battery and plug in the charger?
さんによる
Thank you Andrew. Connected without battery and just cable. It went on but now 500% kernel task makes the computer unusable. Your thoughts?
さんによる
Hey Andrew, cant start it in Command R mode either. What the fudge happened to my laptop?
I'm going to try to copy files over to external HD in 500% kernel task mode even if it takes a long time right now.
さんによる
@albertcav Sounds good. If you run into that problem in the future, you can try Option+Command+R or Option+Shift+Command+R instead(The process is different for Apple Silicon devices).
さんによる
Are you saying this machine is done? Once I get my files etc from HD. How do I fix this machine if I do at all?
さんによる
2件以上のコメントを表示
コメントを追加
2件の回答
ベストアンサー
For kernel_task taking up 500% of CPU power, I would:
  1. Back up the drive if you haven't. To do this:
    1. Shut Down your Mac if it isn't already off.
    2. Connect a hard drive or solid state drive via USB.
    3. Press the power button. Immediately, start holding Command+R.
    4. Keep holding Command+R until you see MacOS Utilities.
    5. Choose Disk Utility
    6. Create a partition on the external drive(Mac Format)
    7. Choose “Restore”
    8. For the source, select Macintosh HD(or whatever your MacOS partition is called)
    9. Wait. This process may take a few hours.
    10. Once the restore is done, exit Disk Utility and Shut Down or Restart the computer.
  2. Reset the SMC: Disconnect the AC Adapter, hold the power button for 5 seconds, then reconnect battery and AC adapter and power on the machine.
What happened after completing step 2?
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
Hi Andrew,
How do I back up drive with this kernel task ruining everything?
And
What is step 2?
さんによる
@albertcav I have updated my answer. It should make more sense now.
さんによる
After step 2 no change at all. Going to back my hard drive. I found an external. It will not run on the battery.
さんによる
Safe mode btw doesnt work, wont get to desktop
さんによる
コメントを追加
both software and hardware errors may lead to this case.
firstly, you may take out the removable battery and plug it with outlet. If it doesn’t help, it means it’s not battery problem.
Then, try resetting SMC:
Make sure the Mac is shut down.
Plug the USB cable to the Mac and power source.
Press ''Shift + Control + Option + Power keys together for 10 seconds.
Then, press Power to turn on the Mac.
Check more details.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thank you Cassie Wu, I disconnected the battery and turned on with the just the power cable. However now 500% kernel task makes the computer unusable. Your thoughts?
さんによる
コメントを追加
回答を追加する
Albert Cav さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 21
今までの合計 706
