メインコンテンツにスキップ
IBM社が販売し、2005年にLenovo社が買収したビジネス向けノートパソコンのシリーズ。旧モデル(Pre-XX50)にはWiFiホワイトリストがあるため、ワイヤレスカードの交換は、オンラインで一括してジェネリックカードを購入するほど簡単ではありません。
712回答 すべてを表示
Lenovo L480 not booting but power LED is on
  • screen is blank, caps lock LED doesn’t light up
  • power LED and the red LED outside are on
  • holding down power button doesn’t do anything however the red LED blinks off and on every 7 seconds
  • when plugged in white charging indicator lights up
  • holding down power button while plugged in, red LED flashes on 3 times every 5 seconds and then turns off
  • this model does not have a reset hole or removable battery
please advice
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Hi @g0f0ndwyxr ,
Try a full power refresh and check if this resolves the problem.
Here’s the procedure:
Disconnect the charger if connected and turn off the laptop.
Dis-assemble the laptop and disconnect the main battery from the motherboard. You only have to disconnect it, not remove it.
Disconnect the coin cell RTC battery from the motherboard.
Here’s the hardware maintenance manual for the laptop. Go to bottom of p.75 & then to p.77 to view the necessary pre-requisite steps and then the procedure for how to access and disconnect both of the batteries.
Press and hold the laptop’s Power button for a full 30 seconds to dissipate any residual charge from the motherboard. This will reset the BIOS which may have become corrupted preventing a normal start.
Reconnect the coin cell battery and the main battery.
Re-assemble the laptop and connect the charger.
Try to turn on the laptop and check what happens.
このアンサーは役に立ちましたか?
スコア 3
6 件のコメント:
I can't do that the laptop is company property. I knew working from home was a mistake.
さんによる
@g0f0ndwyxr Well the laptop will break even in the office, do not blame WFH.
さんによる
@thesimpleguy and I could have had a replacement in a day
さんによる
Sir mine also same problem.... please i want to connect with u
https://www.facebook.com/hareeshroyal199...
さんによる
@jayeff Thank you so much for this advice! I already thought I had to send in my machine, but your procedure worked perfectly.
Also the link to the hardware manual was very helpful.
To all hardware newbies: Disconnecting the internal battery is not simple. Just pulling the black tissue does not suffice, it will simply tear. You really have to push the connector out, e.g. using a small screw driver *very carefully*.
さんによる
1以上のコメントを表示
コメントを追加
You may try turning on the PC using another outlet, changing the charger, doing a Hard reset and checking the RAM.
Otherwise check out more methods provided in the post below.
https://www.minitool.com/data-recovery/f...
If none of these worked, it's probably the motherboard.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Worked an absolute treat.. Initially chuffed.. but on checking battery I'm informed " No battery present ". Do I need to get back in & check both connection ports are firmly installed ? Also informing me " Power mode ( plugged in ) . Better performance "
さんによる
コメントを追加
回答を追加する
juliana restrepo さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 19
過去 30 日: 89
今までの合計 14,650
