メインコンテンツにスキップ
Microsoft Corporationが設計したXbox One Sは、2016年8月に発売されました。Xbox One Sは、Xbox Oneを再設計した製品です。
Water damaged - Cleaned but turns off immediately after turning on
My nephew spilled water into my XBOX ONE S and since then the console has been faulty. I have taken it apart and cleaned off all the visible water damage. The damage was mostly to the bottom left (front) side of the system so it seems that the more important components were spared. I cleaned it using Surgical Spirit and a toothbrush.
However the system still is faulty. When I turn it on, it’ll make the beep, start spinning the fan and then quickly turn off again. Is the system gone for good or is there anything I can still do?
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
ifixit actually recommends that you deconstruct and teardown your ENTIRE system and submerse ALL damaged components in >90% isopropyl alcohol RIGHT AWAY and clean and scrub it while it is submerged and then remove it and dry it thoroughly and put it back together. Attached is Ifixit’s official guide on repairing water damage and i suggest you follow it closely: Electronics Water Damage
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Altair 007 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 134
