メインコンテンツにスキップ
モデル番号A1502 / 2.4, 2.6, 2.8 GHz デュアルコアIntelプロセッサ/ 2013年10月発売
552回答 すべてを表示
Battery not charging, magsafe 2 light not showing
Hi,
The computer's battery is not charging, as described in the picture:
The magsafe connector has no light indicating its operation.
I used another connector to test if the problem was in the cable, which is not the case, the other connector also had no light, and in the same way as the previous one I could make the computer work but not charge the battery.
The battery is new, I changed it after I got a message that the old battery needed to be changed. I don't remember exactly, but I am pretty sure that before I changed the battery this problem already existed.
Sometimes, especially when the computer is warm, the connector lights come back on and the computer battery charges normally. This makes me believe that I probably have a hardware problem.
Coconut battery picture for reference:
Any idea what the problem might be?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Often the contacts and insulator area is dirty
Make sure your’s look like the bottom one in this image
Otherwise the MacBook Pro 13" Retina (Late 2013-Early 2015) MagSafe 2 DC-In Board maybe bad. I would also inspect the logic board connections from the DC-In Board our corrosion on the middle contact as thats the one wire comm link to the charger. Here’s the guide MacBook Pro 13インチ Retina Display Late 2013 MagSafe DC-Inボードの交換
MacBook Pro 13" Retina (Late 2013-Early 2015) MagSafe 2 DC-In Boardの画像
製品
$14.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mike さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 19
今までの合計 100
