メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2.3GHz, 2.6GHz, or 2.7GHzクアッドコア Intel Core i7 プロセッサ (Turbo Boost 最大3.7GHz) 6MB 共有L3 キャッシュ付き。
How to remove stuck (stripped/damaged patch/thread) screws?
Hi,
I was trying to replace the speakers of Macbook Pro A1398 following this guide MacBook Pro 15" Retina Display Mid 2012のスピーカーの交換 and I’m stuck at step 31.
I’m unable to remove one 2.6 mm T5 Torx screw (red) and one 5.8 mm T5 Torx screws (left orange one) due to their screw patch (thread) is damaged.
Is there any possible way to remove them using any tool? Any help would be highly appreciated. Thank you.
Best regards,
Arif
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
You should be able to replace the right speaker as the screws holding it are exposed.
Are you using the proper sized screw driver, is yours worn? I would get a fresh tip/driver to see if that solves the problem. You also need to press down a bit Make sure you open the display so it is hanging over the edge of your work table and have something to pad the keyboard (thin towel or sheet of real chamois leather)
See if a scrap of chamois leather can help in getting a good bite with your driver. I also find a small drop of solvent around the screw head can sometime help and in other cases a soldering iron heating the screw can also help.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Hi Dan,
Thank you for the tips. I used a new T5 but there’s no grip. May I know where can I find a soldering iron to heat the screw?
Regards,
Arif
さんによる
@arifk - Something like this should do it Soldering Iron 60w Hakko 503F
さんによる
@danj, thank you very much. Appreciate it. Let me try out the methods you mentioned.
さんによる
コメントを追加
回答を追加する
Arif Khan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 6
今までの合計 281
