メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2020年10月13日に発表され、10月23日に発売されたAppleの2020年フラグシップスマートフォンです。6.1インチOLEDディスプレイ、トリプルレンズ、LiDARを搭載したリアカメラシステム、5G対応です。iPhone 11 Proの後継モデル。
Is there a repair guide for replacing the glass back of the 12 Pro?
Is there a DIY repair for the glass back of the iPhone 12 Pro? I see parts being sold online but I do not see a repair guide on this website.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 7
コメントを追加
1 件の回答
最も参考になった回答
There will likely be one in the future on iFixit, however it's not really an easy process at the moment so not practical, especially for the DIY repairers.
*EDIT: Just had a quick look and there is a guide that involves the laser machine here
I'm lucky enough to work with a $4000 laser machine that is used to laser off the adhesive between the glass and frame so it can be broken and chipped off slowly. We also have to use specific diagrams when lasering or else risk lasering an antenna from the device. Then the replacement glass is glued on and bonded down.
If you don’t have an expensive laser removing all of the old glass and adhesive is really tricky o do cleanly and if a small piece of glass is left there when the replacement glass is put on, it’ll all shatter and all be for nothing. It’s a pain because of the way Apple has decided to construct the device, but I’d recommend taking it in to a repair shop for this repair as they can maybe do it same day and with all the correct equipment, but without charging as much as Apple might.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
michrobi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 15
過去 30 日: 39
今までの合計 2,755
