Which product kit I should buy to fix the ipad mini4 digitizer
I only find the kit for ipad mini 1/2 on the store, will it work with my ipad mini4?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Unfortunately the iPad mini 4 uses different components for the display and digitizer than the mini 1 and 2. The iPad mini 1 and 2 use a separate LCD and digitizer while the mini 4 uses a design that fuses both parts together into one display assembly. If you need to replace the digitizer, you will need to replace both pieces as one unit.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 4
今までの合計 41
