メインコンテンツにスキップ
モデル番号A1312 / Mid 2010 / 3.2 GHz Core i3もしくは2.8 & 3.6 GHz Core i5もしくは2.93 GHz Core i7, ID iMac11,3
382回答 すべてを表示
Can I use it as a display only?
Is it possible to connect a mac mini to my iMac and use its display? How can i do that, what will i need and are there issues that i might face?
Update (07/31/2021)
Will i encounter issues like the following?
- The iMacs display will be at maximum brightness
- iMacs fans will run at full speed because of the heat
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
5 件のコメント
You can use the brightness keys on the Mac Mini's keyboard to adjust the brightness. I'm not sure why the iMac's fans are running at full speed.
さんによる
@andrewsawesome have u actually tried to make the brightness adjusting from the mini keyboard and it works?
さんによる
@genik I don't have an iMac. You can also use the Display Preferences on the Mac Mini.
さんによる
@andrewsawesome on what Mac have u tried your suggestions?
さんによる
I haven't tried my suggestions.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Apple Support Article
You will only be able to use Target Display Mode (to display a Mac Computer on an iMac) if:
2009/2010 iMac:
  1. The iMac is running MacOS High Sierra or earlier and has a Mini DisplayPort connection on the back.
  2. The Mac you want to view on the iMac was introduced in 2019 or earlier, is running MacOS Catalina or earlier and has a Mini DisplayPort connection.
  3. You have a Mini DisplayPort to Mini DisplayPort cable.
2011-Mid 2014 iMac:
  1. The iMac is running MacOS High Sierra or earlier and has a Thinderbolt or Thunderbolt 2 connection on the back.
  2. The Mac you want to view on the iMac was introduced in 2019 or earlier, is running MacOS Catalina or earlier and has a Thunderbolt or Thunderbolt 2 connection.
  3. You have a Thunderbolt or Thunderbolt 2 cable.
How to use Target Display Mode:
2009/2010 iMac:
  1. Turn on the iMac.
  2. Turn on the other Mac and log in to your user account.
  3. Connect the two computers using a Mini DisplayPort cable.
  4. Press Command+F2 on the iMac's keyboard to enter/exit Target Display Mode
2011-Mid 2014 iMac:
# Turn on the iMac.
  1. Turn on the other Mac and log in to your user account.
  2. Connect the two computers using a Thunderbolt/Thunderbolt 2 cable.
  3. Press Command+F2 on the iMac's keyboard to enter/exit Target Display Mode
To control brightness: On the Mac that is being displayed, use the brightness keys on the keyboard.
To control sound: Click Apple Menu>System Preferences>Sound>Output and select the iMac as the sound output device.
このアンサーは役に立ちましたか?
スコア 3
10 件のコメント:
My iMac is a mid 2010 version and it’s equipped with a mini display port.
さんによる
What Operating System is your Mac Mini running? What Operating System is your iMac running? Does the Mac Mini use an M1 processor? Does the Mac Mini have a Mini Display Port output on the back?
さんによる
Mini uses ElCap and the iMac uses HighSierra.
Mini has an IntelCore2Duo processor and the iMac a corei7
Both have a MiniDisplayPort at the back
さんによる
Do you have a Mini DisplayPort to Mini DisplayPort cable?
さんによる
Are there short ones i can use?
さんによる
5件以上のコメントを表示
コメントを追加
回答を追加する
genik さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 5
今までの合計 130
