メインコンテンツにスキップ
2017年11月4日発売。モデルA1865、A1901。GSMまたはCDMA/64GBまたは256GB/シルバーまたはスペースグレイ。(発音は「iPhone 10」と同じ)。
1200回答 すべてを表示
Would screen replacement fix green lines/flickering on screen?
What are the chances that a screen replacement would fix a flickering screen that partially does not display an image, following water damage?
My iPhone X was dropped in water, and has now dried out and seems to be functioning except that:
  • screen has a slight flicker (light horizontal lines quickly oscillate across entire screen)
  • the top right corner is not displaying an image (has a combination of bright green lines and black),and
  • the top left corner has a dimmed image.
While the phone was drying out, at one point it had vertical green lines running down the length of the screen, though this does not appear anymore.
Picture of the current error:
https://drive.google.com/file/d/1berZouJ...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
Green lines and flickering is usually indicative of physical damage to the LCD or OLED panel underneath the glass, and would most often be resolved by a replacement screen, however with the water damage there may be a little more to it. If the device actually functions completely fine now with no errors or anything you might have gotten lucky. I’d recommend taking out pretty much every component to scrub down with some alcohol based cleaning solution that’s safe for electronics, and then put it all back in with the original screen(also clean connectors of screen flex cables) and see if it’ll work. If the issue is still persisting then replace the screen and everything should be fine!
If possible it may even be worth going to a reputable repair shop to see if they can diagnose whether or not it’s worth getting the screen replaced.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
help my phone screen is broke and my dad is going to be !#^&@@
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
p
i
s
s
e
d
_
さんによる
コメントを追加
fixed the same problem by bearing my iPhoneX in beg of rice for few days to finish drying off its internals after successfully resurrecting my old Motorola in the same way from a drop into a toilet bowl years before:-)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Prv8E さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 17
過去 30 日: 70
今までの合計 3,693
