メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Why doesn't my iPhone 6 refurbished replacement screen sit flush?
Hey guys,
I recently replaced my iPhone 6 screen with a refurbished display from Easyphix, and after switching over the components from the old screen to the new one and installing the new screen, I noticed that while the top of the screen fit properly, the rest of the screen was slightly lifted up from the phone chassis [See image here or below - https://imgur.com/a/zRpb8ut ]. (The gap on the right is ~1mm wide and properly depresses when I press down on it so I don’t think its due to a blockage of some kind. Perhaps faulty screen clips?)
I should also note that with the old screen, I cant tell whether that has the same issue since it has so many cracks make parts of it not sit flush anyway.
I've tried fixing the slight bend in the phone but that didn't help. I've also made sure all screws are screwed in well.
The only solution I've found to a similar problem was to replace the battery due to potential swelling, however looking at the battery, it appears completely flat so don't think that's the problem.
Any ideas, and suggestions will be greatly appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
If the screen sits properly when pressed down, it might just need some adhesive near the bottom of the frame. The bottom of the screen doesn’t have many (if any) clips, and adhesive should hold it down. Hope this helps!
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Ooh that's a really good suggestion. Do you thinkg using an adhesive for the iPhone 6s would be the right size and be strong enough to prevent this spring back? (because the iPhone 6 doesn't have its own screen adhesive)? or just any double sided tape?
さんによる
Most double-sided adhesive tape should work, as long as it is pretty strong. I’m not 100% sure if iPhone 6s adhesive will fit the frame, but even if it did I don’t think it would be strong enough to hold it.
さんによる
Ok sweet! I'll try that then, thanks.
さんによる
コメントを追加
回答を追加する
Gordon alberts さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 4
今までの合計 130
